AIO and airflow for Corsair Carbide 375R
19 Sep 2008
Hi all,
I could do with some advice regarding an air flow upgrade. I am currently using a Corsair H55 to cool a Ryzen 5 3600 in a Corsair Carbide 375R. I have 2x 140mm Noctura fans in the front panel, the H55 Mounted to the back panel and a single 120mm in the top of the case. Not ideal as the Nocturas are probably overkill compared to the exhaust.
Ideally I would like a 360mm three fan AIO to give me headroom for overclocking and a processor upgrade. I have my eyes on the Corsair H150i pro and the NTXT Kraken X73. The case apparently does accept a 360mm radiator but it has to be mounted in the front panel. This would limit my options for an exhaust and would render my 140mm fans unusable.
Could you guys give me some advice? Should I consider a 240mm and top mount it? Love noctura fans but they are a bit of an eye saw in a completely black build, what 120mm fans should I consider for top and rear exhaust? Should I go Corsair or NTXT?
Thanks for any suggestions!
Al
spec:
MSI MPG X570 Gaming Plus
AMD Ryzen 5 3600
16GB Corsair Vengence RAM
2070 super
Phanteks AMP 550W modular
You could put a 360mm rad at the front and have a reverse airflow setup.
Rad fans as exhaust and 2 top fans and rear fans as intakes.
Arctic p12 pwm fans air excellent value/performance.
