AIO bought for LGA1700 perhaps is not??
27 Jun 2016
I have just bought and received a EK Water Blocks AIO 360 basic because I was doing a new build based on the new 12th Gen Intel that just came out. So new CPU, motherboard and cooler.
There were very few that mentioned LGA1700 and chose the EK Water Blocks AIO 360 basic out of those OCUK website said would support it.
https://www.overclockers.co.uk/ek-w...-in-one-cpu-water-cooler-360mm-hs-00t-ek.html
Problem is, now that I have it in my hands, there is no mention of 1700 on the box and don't want to open it and find it doesn't and they have mis-sold me it.
Can anyone, on the forums confirm it can or cannot be used for an LGA1700 mobo please?
I have took screenshots of the webpage of proof that OCUK have advertised it as 1700 compatible, just in case.
Perhaps the box predates 1700?
But the parts in it anyways
No idea how long that aio has been around
If they already had a load of boxes made maybe they used them anyway
and just put any extra part in there and updated the Web page description
But opening the box is what to do to find out
If its not in there either ask for it ocuk should give you one
If they don't have it ek should give you one
Or return it as not suitable
Mine wasn't in the box and I had to contact OCUK to send one out however they explained the system was meant to automatically generate one to go with the AIO but it didn't so odds are if you haven't got one outside of the box it isn't there which I found out recently.
