- 1 Dec 2015
I'll assume you are speaking of next gen Liqtech TR4 and no, I do not recommend it. From what I have read of owners posting on internet by owners of Liqtech TR4 having taken weeks to get a reply, much longer to get replacements, and not being offered a refund when there is a known problem I cannot recommend them. While most have got replacements it took way longer than it should have taken for them to get those replacements .. and several have had the replacements suffer same problems. So no, no recommendation here.
Yes, I recommend be quiet! Silent Loop AIOs. If you get one service it at least every 18months if not yearly. All H2O loops need to be cleaned and serviced regualry.Silent loop
Had not looked at EK-MLC Phoenix, but then with all the peeps who have had problems with EK-WB customer support I don't look at them. Looks like the only reason it cools any better than something like be quiet! Silent Loop 280 or 360mm is because of higher noise, higher performance fans. Looks to be a decent product. Please let us know how it all works out.I decided to give the EK mlc Phoenix a go after reading loads of reviews of the enermax unit i'm not sure i can trust it until the second gen units are out and reviewed. I had a measure up lastnight and it's going to be VERY close at the front with a 360 rad in the front of my air 540 and the 1080's. Am i wrong in thinking that with the EK semi modular stuff i could put a 240 rad in the top of the case if i needed more cooling? Kind of a step between AIO & a full custom loop? I could be miles off though.
I certainly will do, If it's no good it will be returned and maybe i'll look at a custom loop, Just don't think i could swing that past the wife along with a new cpu, mobo, ram & cooler!Had not looked at EK-MLC Phoenix, but then with all the peeps who have had problems with EK-WB customer support I don't look at them. Looks like the only reason it cools any better than something like be quiet! Silent Loop 280 or 360mm is because of higher noise, higher performance fans. Looks to be a decent product. Please let us know how it all works out.
So after a few weeks of testing now i'm very happy with the noise & performance of the EKWB mlc phoenix. The 360mm rad was a squeeze in the case (corsair air 540), It meant i lost the front most hot swap bay in the bottom but that's not really a problem as i rarely hot swapped drives anyway!
In my 22°C room it idles around 28-30°C with PBO enabled and isn't audible at all, After encoding for a few hours it gets up to around 58°C with the odd spike to 63°C and with the fans on a quiet setting in speedfan 5 it is still quite quiet. I may swap the fans out for some noctua's in the future if the noise starts to bother me or i need a bit more performance.
Price wise, Yes it was more expensive than competitors but i do like the fact i could throw my gfx into the loop in future if i wanted. Zero leaks is also a massive bonus after the last generation!!
