Hi everyone,
So something that's always bugged me is how hot my system seems to run, today I done some testing and got the following results:
Desktop Idle:
Socket temp - 38-40 degrees C
Core temp - 19-21 degrees C
Prime95 test (10 mins):
Socket temp - 56 degrees C
Core temp - 43 degrees C
My setup is:
Asus Sabertooth 990FX R2 Mobo
AMD FX-8350 CPU (stock clock 4GHz turbo mode)
Sapphire R9 280X Toxic
16gb Kingston HyperX Beast 2400 MHz DD3 RAM
Samsung 840 Evo 240gb SSD
Corsair Carbide 500R case (stock fans given with case)
Corsair H105 CPU cooler (fans mounted in push config)
Arctic Silver 5 thermal paste
I'm looking at playing some more demanding games such as GTA V, Rainbow 6, and want to upgrade my GPU in the new year, but I feel like the system is running slightly on the hot side for stock clock speeds. I would like to overclock and have done before but always ended up resorting back to running the stock configuration as the fan speeds were getting ridiculous even just for web browsing.
I've done some research and found that the 8350 CPU starts throttling around 70 degrees (socket), and I'm not a million miles away from that even after only 10 mins of stress testing, I did actually end up with a blue screen after playing Fifa 16 for not much more than an an hour and 15 mins the other week.
One mistake I have made when building the system is that Corsair don't actually recommend the H105 AIO for the 500R case, although i've managed to get it to fit, could this be an issue to high temps?
Reviews online give praise to AIO coolers, but I seem to feel like I'm not getting anywhere with the Corsair, is it worth switching over to air? Or going for a more dedicated watercooling solution?
The pump does seem to be working, or at least I can feel vibrations when I put my hand on the pump, so I don't believe the H105 to be faulty.
Any help is much appreciated
Desktop Idle:
My setup is:
Report back after you try some different fans in a different orientation!
