AIO fan orientation?
31 Dec 2006
I have a Nepton 240M which I'm mounting to the front of a Cooltek W2 as intake. Does it matter which side of the rad the fans go, i.e closer to the outside, or more visible on the inside? Which is optimal?
If you have a fan that makes a seal with radiator (the square ones) there should be no real difference maybe 1-2 Celsius degree which is reading error more likely. Many people although prefer to put a fan to push air either to the case or out pushing air though the fins of radiator to the case or out.
