Aio gpu block in custom loop?
6 Mar 2010
Hi,
I’ve got an option on a great deal for a 1080ti, but it’s a version with an all in one cooler. Can I remove the fan/pump and use in my custom loop? Or will there be issues due to different flow rates and pressures?
Pretty certain most AIO GPU's are not ones you can dismantle, they are mostly sealed units so you will not be able to take them apart (or at least easily) and add them into a custom loop, or at least most the models I have seen.
I thought as much, thanks for the info!
