AIO hose combes
11 Jul 2003
Telford//west mids
Looking for something to tidy my aio hose on my artic freezer 3 420 mm, any ideas.
Outer diameter 12.4mm
They sell them on the usual sites
Aio hose comb,separator,router are few of
The names I have seen for them
Or if have access to 3d printer
Thingiverse and other 3d file sites
Have loads of them
Could also use a aluminium fuel/billet clamp line - AN4 or AN6 I would guess?
If you can find 3d printer as mentioned
You can also print ones that hold the hoses/tubing
Further apart and parallel
Rather than right next to each other
Depending how you require them positioned
If you want something that looks different
Have also seen 3d printed "spines" to do it
The AN4 mentioned by pre
Is 11mm I think but the way they go on you don't have to
Fully tighten them so will fit
Wouldn't be first time i used car parts in my loop lol
But usually been tubing as wanted it the same day
If they are not good, just use some velcro straps, 2 or 3, this is what came with my Mrs new Deepcool cooler and does a pretty decent job of keeping the hoses tidy.
I have the white cable ties on there at the moment and it don't look too bad, like you say I've also looked at white velcro, so I'll see how they look when they arrive.
