AIO making 'whooshing' noise... normal?
31 Dec 2006
My AIO is making periodical whooshing noises. Is this normal? Temps are absolutely fine, no issues with performance at all, just this odd noise is a new thing.
What make/model is it? Probably fine more than likely just the pump working I'd imagine but I'd keep an eye on it for any leaks, the reason why I don't use AIO.
Probably sucking a air bubble through, I'd give your case a shake side to side and see if it continues.
It's a Cooler Master Nepton 240M. No leaks or anything, that was my first thought. Doesn't happen all the time, so I suspected an air bubble or something. Temps and performance is rock solid, no issues... just that odd noise now and again. I'll give it a bit of a shake, see if that resolves it.
