- 2 Aug 2005
- Cleveland, Ohio, USA
Howdy there boys and girls. Long time no chat. I happened across a sore willy deal on a Corsair H150i AIO. I already had an AIO on my CPU so I decided to YOLO it and try to cool my GPU. I'm having some issues mounting it.
Spec:
After some futzing around I decided there was no good way to use the NZXT Kraken G12 I bought for the purpose (Aside from that the H150i doesn't use the round Asetek coldplate assembly so it wouldn't have worked anyway). I used a round file and cut down the Intel bracket and backplate included with the cooler. It fit pretty well, and I got some spectacular temps 37C after an hour of heat soaking with FurMark down from 85C.
I've got the backplate outside the factory decorative backplate because there are some IC's in the area of the GPU that would interfere with mounting it directly atop the back of the PCB. However, my thermocouple indicated that the VRAM was cooking at 95C. Not good.
I broke it down again and glued on heatsinks using Arctic Silver thermal adhesive. I replaced the TIM with fresh Arctic MX-4 and set up some fans to waft air toward the bottom of the card. VRAM and VRM temps are great now, no warmer than about 45C.
Pay no attention to being in a bottom PCI-e slot. Took this pic when experimenting. It's in the top slot now.
GPU temps and performance, on the other hand are not good. My boost clocks are 200MHz lower and GPU Shark indicates I'm at thermal limit at just 65C. The thermal limit is a mystery to me. What's up with that? It ran at ~2000 MHz and 85C on the factory aircooler.
There're only a few things I did differently between the two setups. The first time I had higher mounting pressure. I saw when I went it take it apart the PCB was flexing quite a bit, about 0.5mm across the width of the mounting bracket. I tightened up the cooler until the PCB just started to deflect, then backed it off a bit. I also rotated the coldplate 90 degrees so the hoses don't block airflow to the VRAM modules.
Running Folding at Home simultaneously on the CPU and GPU I've leveled off at 36C water for the CPU with package temps at 72C for the CPU. 29C water with GPU package temps at 51C. GPU-Z only shows 85% utilization on the GPU which may be why it's below that 65C thermal limit I ran into before.
Anything obvious I should be doing to try to mount the cooler; brackets, clamps, something I can just buy or make to help? Any insight on the thermal throttling at only 65C?
Thanks in advance!
Spec:
- Proc: AMD Ryzen 3700X
- Mem: Crucial 2x16GB DDR4-3200
- Mobo: Asrock X570 Phantom Gaming 4
- GPU: Zotac RTX 2080 Super AMP
- Case: Lian Li O11 Dynamic XL
- CPU cooler: Corsair H100i Pro (2x 120mm)
- GPU cooler: Corsair H150i RGB Pro XT (3x 120mm)
Thanks in advance!
