You don't have a choice, if you want micro atx AND overclocking you're looking at an AIO water cooler, an air cooler wouldn't fit.
Your exact wordsI didn't say an air cooler wouldn't fit, i said an air cooler that would allow him to overclock 4.6ghz wouldn't fit.
CLC...closed loop coolers?? Hows that diferent to AIO?
Means the same thing
There are air coolers that will do the job that you want
It has a fill plug on the pump and a pump that does flow more coolant than other CLCs, but it is still using aluminium radiator with high fin density and high speed / high airflow fans. End result is it has similar cooling ability at similar noise levels as air coolers. Slap high airflow fans that make similar noise as Triton's fans and you get similar cooling from the air cooler. Only difference is with air cooler the case airflow has to be increased too, or cooler is force to reuse it's own heated heated exhaust air, meaning higher cooler intake air temps and higher CPU temps.
. I researched all kits and went with that one because it has copper radiator and is essentially a prebuilt open loop system as it can be added to should out so wish.Indeed! Swiftechs are quite good.I use a swiftech 220x have 3 fans fitted to it and it keeps up with my overclocking efforts! Just. I researched all kits and went with that one because it has copper radiator and is essentially a prebuilt open loop system as it can be added to should out so wish.
Right now the only ones I know of are Swiftech and EK Predator.
The use of CLC has been around for some time. When Asetek announced / patented the "CLC' cooler concept it was called LCLC for Low Cost Liquid Cooling (or Cooler) .. that became CLC rather quickly. While lower cost than a real liquid loop, they were higher cost than even the best air coolers .. and of course no better unless running at hoover noise levels.I thought the term CLC was used prior to these being around but I must have missunderstood so ignore my comment on CLC and AIO being the same if thats the case
My other point still stands from my experiance of AIOs
Some pumps are noisy and some are not even if its the exact same model, its a bit of a gamble. Fans are always worth considering changing as the supplied fans are noisy in my experience although they can be managed with a fan controller that still means they will be noisy at higher RPMs
I really liked the Phanteks on my old H110, they had a great unobtrusive sound to them under load
