AIO or Watercooled
9 May 2012
South Wales
Hi guys
Im just wandering what everyone's opinion is. At current im running a 240mm AIO Coolermaster kite in my phanteks p400s case, but thinking of changing.
The question i wanna know is it better of stickin with an AIO and saying going for a 360mm or should I go water cooling ?
I ask people these
1. what are benefits if did change ?
2. Is it difficult to set up ?
3. what is more beneficial in the long run ?
cheers mark
A 240mm AIO should manage your Ryzen CPU fine (if its your sig rig) without too much bother even overclocking. Will not see a big change in terms of performance moving to an 360mm AIO or custom loop.
Biggest benefit of moving to a custom loop would be to throw your GPU in the loop also, otherwise no real point from a performance standpoint (and even then). Similarly can add in more radiators and in turn lower fan speed, but will not be a massive gain as I doubt your 240mm AIO is having too many issues. Other benefit to a custom loop is really looks and having it how you want, downside is the dent to your wallet that can occur :p
IMO custom loops are not too hard to do, if you do acylic or PETG bending, can take some time to get some bends done and is a learning experience, but more patience then being difficult.
