- 19 Jan 2013
Hello,
I have ordered my first AIO which is a NZXT Kraken x62 (it comes with 2x 140mm fans) and I am trying to work out where to fit it within my case, I have been doing a lot of research but it does not seem cut an dry. I have a Phantek Ethoo Evolv case which comes with 3x140mm fans and I have an Asus z270e motherboard to control the fans.
I think there are 3 options:
1) Kraken in the front as an intake with 2 case fans in the top and one at the back all acting as exhausts, I would need to manage the speed of the exhaust fans to try to maintain a positive pressure (I think that is correct).
2) 2 case fans in the front as intake and 1 case fan at the back as exhaust, the Kraken in the top acting as an exhaust (pulling air from within the case). Again I would have to control the internal air pressure with fan speed.
3) 2 case fans in the front as intake and 1 case fan at the back as exhaust, the Kraken in the top acting as an intake (pulling air from outside the case). I think positive air pressure would be easier.
Am I heading in the right direction or have I missed something? I am looking for some advice about where to start with it? I am looking for a 5Ghz overclock on a 7700k (silicon lottery allowing) so I think that heat could be an issue.
Many thanks for any help offered.
Niall
Niall
