I have the recent ocuk 6700k bundle with 120mm cpu aio cooler, I was wondering if is ok to vary the pump speed or should it be at 100% constantly (mainly a question about not damaging the pump).
Also, I'm setting up fan profiles for my case (Fractal Design Define S, three 140mm intakes, single 140mm exhaust, and the two 120mm push fans with the rad top mounted) - is frequent spinning up/down of the fans going to affect the lifetime of the fans?
I'm aiming for a constant positive pressure setup, and currently have set up the following:
Front Top and Front Middle intakes always on
Front Bottom intake only kicks in at 55c (to feed the gpu when gaming)
Exhaust kicks in at 50c (didn't want to waste intake air at lower temps)
The aio pump and fans are always on, but on a curve.
How does this sound? Am I overthinking this?
