AIO Question
Permabanned
30 Dec 2021
Yorkshire
The arctic liquid freezer ii 280 as 1 x 1pin PWM cable, this one cable runs 3 fans and a pump
Dose the PWM control just the fans or the pump too? if you use fan off would that also be pump off?
My system as full RGB fans but i was going to put the stock fans at the back of the cooler and set them at a constant low RPM, would this also set the pump at a low fix RPM?
Yes pump and fans would be controlled together
If you want separate control you need to examine cable and connect fans and pump separately (there are spltters/joiners inside the sleeving)
