Recently purchased an AIO cpu cooler, coolermaster 240. Have 3 system fans already all 140mm, phantek fans.
Case is: https://www.overclockers.co.uk/phan...black-full-acrylic-side-window-ca-040-pt.html
Gpu is sapphire Nitro+ rx480 8gig.
Torn between:
Radiator at front with fans set to intake, 1x140mm top exhaust and 1x140mm top rear exhaust - both set to lowish rpm.
Or
Radiator at top as exhaust, 1x140mm top rear exhaust and 2x140mm front intake.
Would I see much higher difference between the 2 configs? Or is it just going to be personal preference.
Read that it's best to aim for slightly positive pressure but also read that negative is better for cooling.
PC is kept on a short thread carpet floor in a low dust room.
Torn between:
Or
