AIO Radiator - mounting with inlet/outlet at the top or bottom?
15 Nov 2007
Hertfordshire
I've got an NZXT Kraken AIO because I wanted some fancy cooling without the hassle of a custom loop (and I got rid of all my w/c stuff years ago). When I built the PC, I mounted the radiator on the inside of the front panel with the inlet/outlet at the bottom of the rad, but everything I see an AIO in a case like mine (NZXT Source 340 Elite) the radiator seems to be mounted with intlet/outlet at the top of the rad.
Does it make any difference? Should I change the radiator orientation?
The manuals say it makes a difference but logically it shouldn't. The pump has to push the water up either the return half or up the front half.
Yeah that's what I thought. Then I thought about air bubbles potentially getting trapped in the block/pump, but if they make to my radiator in the current config they'll just stay at the top of that, which seems like the best place for them.
In my mind (and this is most likely wrong, so don't take it as advice), having the mini-reservoir of the radiator at the top will cause a bit more head pressure and mean the pump has to work less hard to move the fluid upwards.
Edit: seemingly, head pressure isn't a thing in a closed loop, so I was mistaken :D
That said, air has more capacity for compression than water so there is an element of truth in there. I doubt it'd significantly affect the system though.
You need some part of the radiator to be above the block/pump, same as for all water-cooling loops to ensure the pump is primed when it starts. A dry pump can't move anything.
