thanks mate, looks a decent unit..
might be a daft question but do they come with fluid in them?
never looked at water cooing before...
sounds ideal for me then!The AIO stands for all in one so it's basically a whole liquid cooling unit in one, the liquid,pump,block,radiator,tubes and so on. You don't have to refill anything and they last for probably a good 5-7 years depending on how much you instal and uninstall it. Apparently they can last for a max of 8 years according to most manufacturers before they are dead but never had one that long before changing it out or getting a whole new rig.
