- 26 Sep 2017
- In the Masonic Temple
Hello,
I have a standard cpu AIO attached to a 240mm radiator, pump in the cpu block as usual.
Questions is... Can I take off the tubes that are on it and drain the water and then replace the tubes with flex ones and have it part of a custom loop?
E.g res/pump combo ----> cpu block (with pump) --->radiator ?
