Hi guys as above I have a h55 attached to a kraken g12. But it's currently drawing air ( push Pull ) from the fan mount on the floor of the case ( Corsair 750D) Ideally id like the h55 attached to the front of the case... as currently the rad is sitting beside the power supply which gets hot during gaming and it bumping my temps up as well. The tubes are to short and i still have a gap of 10-15 cm to make up.... first i saw what Tiny Tim Logan did with his h100 and realised it was a spoof.... yes i nearly fell for it until i seen the temps!! Anyway got me thinking what about using a shroud to make up the gap between the rad and the front mount.... will this work or will it degrade the air flow?? Or is there any other solutions you guys can offer..... i did consider using the rear fan port but the way the pipes bend it will be putting a constant pulling effect on the bracket of the GPU.
Thanks in advance
Thanks in advance
