I just took delivery of a Carbide 400 Case and a Kraken X62 AIO. I have the AIO front mounted with the fans as pull. I moved the case 140mm fan to the top at 90 degress next to the existing 120mm exhaust fan - both push air out.
My question is this: Soon (I hope!!!) to be getting a Vega64 Liquid card ..... where should I place it's radiator? I can add it to the top, but that could create negative pressure. Or maybe replace the exhaust fan with it?
Another option would be to move the X62 to the top as exhaust and front mount the Vega rad along with the 140mm fan .... the benefit of this would maybe to add another fan if space allows?
This is my first water cooling, so ideas welcome!
