AIO's RGB Fans sync problem
20 Nov 2020
Open field under the night sky
7FvUgxN
Can anyone advice me on how to fix this problem with AIO Fans?
As you can see from the image, the AIO fans and only them are not synced properly. One is off while other only has 1 RGB LED active.
Both (AIO) fans can turn on all RGBS, in the settings upon first start-up. They desync or go crazy after a while, so sometimes they lit up but totally different colour to the rest.
All 6 120 corsair fans are connected to the same RGB hub controller by the way.
I've read somewhere that this is an issue with AMD mobos and Corsair AIO's not syncing properly but couldn't find a fix.
