AIO's with LCD's
12 Feb 2003
Hi folks,
Keen to hear about anyone using one of the fancy AIO's with an LCD screen. How are you getting on with them?
Specifically, either the H150i Elite, or the MSI MEG.
Skip past the fact they're expensive, I'm happy to buy one, just unsure which!
Planned use, will be for a 13700k on an MSI MPG Z690 Force Mobo
I will not be overclocking, it will either go into a P600S or an O11 EVO case
I've had one sat in a box next to an O11 Evo for a few months after i managed to pick one up for the same price as a regular H150i, waiting for my new chip.
I am interested as well to know how other people are getting on with iCue setting them up.
I had the corsair h150i with lcd screen upgrade just prior to moving to a custom loop. It was great for showing off with a comedy gif but the ability to show your temps on it was pretty useful actually and I do miss it: so much so that I'm using a mini lcd screen with a raspberry pi to do the same thing.
The lcd screen is great for monitoring cpu and water temps. I however switched to a custom loop before lcd aio's became mainstream.
I now use a 7" 1024x600 monitor with rainmeter and hoxy 2 skin that i fully customized to show cpu temps, voltage frequency and power. Same for gpu including frame rate and vram usage. System memory usage. Pump water temps, flow rate, speed and power. Also for my m.2 ssd and sound bar.
Got any photos of that?
There's better ways to get a little screen into your case. Probably cheaper as well.
I use the Ryujin II - uses OLED display. As others said you can use it for monitoring temps etc, or use a custom image that you can upload to it. No complaints from me.
