so im planning on getting the air 540 just a couple of things ive been thinking about before i buy it
im going to using air cooling in the case with the exception of the CPU wich will have a liquid cooler on it
i know the case can take 2 140mm fans in the front or 3 120mm fans, i have seen the case with 2 140's in the front and i noticed there is space above and below the two fans
is is possible to get 3 140mm fans with 120mm mounts in the front? i think this would move more air than 3 120's while being quieter
so the overall cooling would work something like this
3 x 140mm fans, front intake
1 x 140mm fan, rear exhaust
rad in the top with 2 x 120mm static pressure fans, exhaust
P.S.
if theres enough space i would probaly put the rad in push/pull, the rad im planning on using is 56mm thick
would i get any benefit from push/pull on a rad that thick? ive heard on thicker rads it doesnt really make any difference
P.S.
