ok mate i try and get some more cash i want to just paont smaller things he biggest ebin computer cases really
i would like to no more fi it is possible would be kind enough to do a spec me please
Hey mate,
well you're about to venture down a complicated path sonny! Custom painting is a different kettle of fish to any other kind of painting, because you basically have to learn how to be an automotive re-sprayer.
anything like computer cases, computer mice, joysticks, controls, cooling equipment (anything that is made of metal or plastic that is to be displayed and handled -models don’t count but can be painted in the same way) will require solvent based paints at least twice during the painting process.
sure you can use Auto air colours, I personally don’t rate them at all over solvent based colours (that's just me though, loads of people use AAC and love it). Auto air is water based, and safe to use, but you will need to use solvent based primers (etch, high build and so on) as well as solvent based clear coats. both primers and clear coats are 2k, or 'two-pack' paints which are paints that harden by chemical reaction when you mix the two components of the paint together. unless you're painting only very small things like mice, you can get away with only having an airbrush to do everything (I use a .5 Iwata to primer and clear coat small objects as it gives an absolutely flawless 'off the gun' finish.
there is a major health and safety issue here by the way, please buy a respirator!!
I'm trying to think of a basic kit that will get you off the ground, but I know just how much equipment I use on a daily basis and it's LOTS.
on a regular basis (today for example, painting a full computer case) I have used 3 different airbrushes and 3 different spray guns. That's about normal for me. the 3 guns I could not do without are my Iwata kustom, my big iwata eclipse and my mini-jet rip off.
I've posted this pic before but it shows some of the things I use daily:
that mini spray gun is well worth getting - you can get them off ebay for about £25. they're not good quality or anything but they are okay for laying down base coats, priming and clear coating. as your collection grows though you will get dedicated guns ( hence I've used so many different ones today!)
for a basic kit look for the following:
Airbrush:
I'd be the first to recommend an Iwata brush, but in this case I think you're going to get a shock when you realise how much paraphernalia you are going to need... so I'd consider one of those premi-air brushes. I've never used one (will see if I can swindle one from airbrushes .com though) but I'd say it is worth a punt as you probably will damage it, ad at least it’s reasonably cheap enough not to worry about too much. I know I said in my last post that a good quality brush is essential, but honestly in this case I think you will get away with this one, and then look forward to buying an Iwata in a different size (that's the start of your collection!)
so grab one of those.
compressor: still need more information mate, you're keeping your cards close to your chest! if you're talking about painting cases... even my 100litre belt driven monster struggles at times! you’re going to be looking at something at least 50 litres.
Paints:
well again, still need a tad more info on what you want to do. but either way you're going to need some practice. I'd decide now if you are going to start using waterbased paints or solvent based. Either way you only need 2 colours - black and white
Primers: in all honestly you will be able to get away with using spray can primers for now. Bare metal and anodised aluminium will be quick to cause you problems though, so use spray cans for now but you will need to get 'proper' paints at some stage.
Powerball:
slightly off topic, but if you don’t have a powerball I'd recommend getting one. That goes for anyone in here who is getting into airbrushing for that matter! (werewolf, I'm looking at you!) it will stop RSI in it's tracks. I use mine all the time when I'm airbrushing, after a while your wrist will start to cramp up and your fingers will ache. sanding things down is really bad for it too. using a powerball will help a great deal in protecting your wrist. I'm using it now, infact
sundries:
depends on the paint system you're using really. but the basics are the same. you will still need the thinners and activators for the water based system when you come to clear coating though!
solvent system:
2k thinner
standard thinner
panel wipe
2k activator
scotchbrite pads and selection of wet / dry papers
tack rags
water based system:
water
panel wipe
tack rags
I dont want to put you off getting into custom painting, but it does involve a lot of equipment and expense, so I think you should get your brush and air source. some blanks canvases, rolls of fax paper or flipcharts and get painting, get practicing. get a feel for it and at the same time research what you need to know, find local paint suppliers who are willing to give you the time of day and so on.
