Any advice for getting the air bubbles out of a monoblock. I've spent all day running the loop trying to get them out. Gentle shakes, running the loop with the pc faced on all sides tilted & flat. Changing the rpm of the pump at alternate levels. Nothing seems to work. These air bubbles are so stubborn, not moved a micro mm.
This is a new build & I'm using a rampage vi extreme ek monoblock & enermax neo changer pump/res combo. What kind of negative affect would leaving the air bubbles in have ?
. Check in BIOS that aura effects are on, off in soft states. You will need to install Aura to control, if you download it the install will not work UNLESS you right click the properties of the zip folder and ‘unlock’ before extracting. Windows 10 security breaks it otherwise, took me ages to figure that out.
