Air Compressors
4 Jul 2006
Ok I am getting really sick of forking out £8 a time for a can of air (Biggest Can Available) and was looking for an Air Compressor that would be suitable (ie, not too powerfull).
Anyone got any ideas.
go to wickes and get a wet n dry hoover about £25, its got a powerful blower.
Ive got one and its brill at blowing the dust out of my pc.
Without mentioning its name but if you go to the uk's number one supermarket you can get a 350ml can of air for only £3 something.
But a small compressor would eventually pay for itself over the years
Airbrush compressor is ideal, typically you'll pay 30-50pounds. Can be had for less second hand.
Simply either use the thin hoze or buy yourself a cheap airbrush to use along with it.
I've used this set up for years.
