Ultra_Extreme said:typically 2-3 years, its pretty common that once air-con dies it stays dead unless you own for many years from new. Not really worthwhile on cars older than 2000 reg as its likely other AC components will be crappy/leaky/damaged. If so you may end up recharging it every few months and never have true air con operation.
So in summary it depends wholly on the car, and importantly the age too.
newbiejim said:I understand that air con needs 'recharged' periodically, my question is typically how long between recharges and how much does this cost?
Oracle said:Doesnt actually EVER need re-charging if its used all the time. Remember, air conditioning is exactly that. An air conditioner. Its not a chiller unit.....use it with warm air and its fine...leave it on all the time and adjust the temp accordingly and you'll never need to service or recharge it.....
Oracle said:no, its a conditioner, the condenser causes it to chill with the aid of the fan.
In 10 years of my grandad owning a 7 series BM with aircon (which is on all the time) he has NEVER had it serviced or 'refilled' and its colder than my mums 53 plate Yaris!
Clarkey said:£25 if you know the right people![]()
