- 24 Oct 2002
- Derby / Rotherham
Where would be the best place to get an aircon service, dealer of specialist. I've noticed over the last few weeks that its not as cold as it should be.
what exactly do you mean by "the last few weeks"
I dont think its been above 4 degrees in at least the last fortnight. Least not here in yorkshire
Bare in mind that below about 4, its too cold and aircon compressor wont kick in and the aircon wont work. Only way to get it to work is to wait till spring![]()
( |-| |2 ][ $;15701358 said:Again mine wont come on at all below 3-5C. I've no idea why anyone would need it with temps below 15C though.
Because it dehumidifies the air? It doesn't just cool it.
( |-| |2 ][ $;15701405 said:True but it's not exactly 99% outside is it, if there's damp in the car and the screens mist up then that's another fault entirely. Either way the OP is complaining of not getting cold temps.
how about if the snow comes off your feet and melts.....
Major fault with the car I guess?
( |-| |2 ][ $;15702512 said:Without getting into a full on argument can I say that the normal blowers should be able to handle that no problem?
