Man of Honour
- 21 Nov 2004
Finally getting air con in my gaming room and probably spare bedroom since it can be split off the same unit on the same side of the house. That’ll be the whole house air conditioned then
(currently have the lounge, kitchen and master bedroom with units fitted). I suspect I’d use it in my gaming room all year round - small room, lots of heat generation, can’t open the window. Thought my XSX would output less heat than my PC, but the TV it’s connected to has more than compensated.
Edit: all booked in. Decided to get two individual systems, cheaper and less mess than another multi split.
(currently have the lounge, kitchen and master bedroom with units fitted). I suspect I’d use it in my gaming room all year round - small room, lots of heat generation, can’t open the window. Thought my XSX would output less heat than my PC, but the TV it’s connected to has more than compensated.Edit: all booked in. Decided to get two individual systems, cheaper and less mess than another multi split.
