You are ignoring the other aspects of an inverter heat pump.
Our system will be used all year round, hot or cold, damp or dry
- They also pump heat into the house at a 300% efficiency rating (meaning they pump 3KW of heat into the house for every 1KW of power consumed) - Big savings over my existing 100% efficient electrical system, one third of the cost! 11p/KWH translates to a useful energy heat unit costing equivalent of 3.66p.
- They also dehumidify, so your example of in a few weeks it be raining and damp (ie, high humidity), you can now control the humidity inside the house resulting in it being much more comfortable.
- The bonus too is obviously the cooling aspect as they can pump heat both in and out - so stable all year round.
Yeah I understand what you mean I was mentioning my cheap fan blowing out the window isn't quite the same as a split air, its great a split air exist but for people on a budget and needing a quick summer fix with a £16 quid fan and 5 minutes they can really improve the air flow and quality in their homes.
I don't know a great deal about these splits but it sounds like its half replacing the boiler central heating system and radiators ?
humidity can be a real issue but I improved mine with placing bowls of water around the home and on shelves, under radiators and I leave the bathroom door and let the steam spread out in the house. And I also keep ventilation guards on windows and in rooms open when needed.
Sound like a right tight git which I am but it works ! my humidifier machine did next to nothing for improving air condition in my home sadly apart from making the place wet.
