I'm looking at getting air conditioning for my room. Now before people shout that it's pointless in the UK please read.
I have a small room (3.6 x 2.8 m) the windows are very small opening, I keep the door shut, I'd rather have the windows closed to reduce noise from outside and my music/movies being heard outside.
My room gets very hot with everything running, here is what's in my room.
60" plasma - gives off a lot of heat.
2 x amplifiers (Stereo and AV)
High end computer overclocked of course
HP Microserver
Subwoofer with amp
Modem and router and other things.
It doesn't need to be warm outside for it to get too hot in this room. Also I only have storage heaters which suck, I'm told these air con units cool very efficiently.
I'm looking at Mitsubishi SRK HG units.
2.6 Kw 9,000 BTU unit or
3.6 Kw 12,000 BTU unit
The seller suggests the 12,000 unit and it's only £50 more, should I go with his advice?
I tried some calculators and they say 9,000 is plenty for the room size, but I'm worried with the plasma I will need more.
If anyone with knowledge can help I'd appreciate it.
Thanks
HP Microserver
Subwoofer with amp
Thanks
