- 9 Nov 2020
Hello!
I have gathered tons of excellent advice and tips in this forum over the years, but this time I actually had to register and make a post myself. Go easy
I just finished my Level 20XT-build, and I went really overkill. But somehow the air/coolant-delta is higher than I would have imagined it to be. I'm not super-experienced, this is my third build, but something seems off.
When ambient is around 22C, my coolant hits upwards of 36C even with my fans around 80%. Thats about 1200rpm for the ML120s and 900 RPM for the ML140s. Kinda noisy!
I removed the dust filters, and tried ins and outs on all fan positions. Things did not change much. I obviously haven't tried everything yet, so I am really hoping for some good tips towards different solutions I could try out.
Here is the cooling:
Water:
TOP: 2 x 420 Nemesis GTS with 2 x 3 140ML Corsair - PULL (600rpm quiet - 900-1050 gaming)
Bottom 1 x 480 Nemesis SR2 with 4 x 120ML Corsair - PULL (600 quiet - 950-1200 gaming)
D5 corsair pump/res (2500rpm quietmode - 3500-4000 gaming) + corsair blocks for 3800x and 2080 ti on a 360W bios going full tilt.
Air:
Front: 2 x 200mm TT riing plus (going at 550 rpm)
Back top: 1 x 120 ML120 (AIO-one that goes to 2400RPM, usually sits at 600-1200 like the ones on the SR2)
Back bottom: 1 x 140 slimfan (not here yet, but it won't help much)
So the case temp sits around 32C when gaming for 1 hour+, but right now I'm having all three rad-setups drawing air from the outside, so temp inside the case shouldnt matter much for coolant was my logic. I can lower the case temp to 27-28 by just taking off the front housing. That gives those huge 200mm-fans actual air to suck in.
When idle the temps just stops at 27 for air inside case and coolant around 28, even if the ambient is around 21-22.
I have a small leak in the SR2-rad, one of the bottom caps is leaky - I ordered a metal replacement. Doubt it matters much, we're talking a few drops per day.
Wow. That was long. Sorry about that, and thanks so much for any tips.
Water:
Air:
