Air cooler for a phanteks shaft 2
Permabanned
30 Dec 2021
Yorkshire
Low profile options.
This case
I'm cooling a 5600 that will be at stock and under volted
If I used a Be Quiet! Shadow Rock LP, it as a tdp of 130 but will only have 10mm of room to get air is that OK??
Or should I get one of the lower coolers lock like a Alpenföhn Black Ridge thay as a tpd of 95 but will have 37mm of room to grab air
Or other options?
I would try the BeQuiet and see how you get on. This is the downside of all these tempered glass cases as thin cases used to have a vent over the cpu cooler location so it could suck air in.
