Hi all, I picked up 3600x build a few weeks ago Motherboard is a MSI B450 tomahawk max and im using 8 packs cas 16 3600mhz ram.
I've used the stock cooler until now, which to be fair for a in the box, cpu cooler doesnt do a bad job. But the noise
the constant ramping up and down when pushing the cpu or playing a game is driving me insane I've had a quick play with fan profile so its fine for normal use. But anything else its like a harrier jump jet on take off.
The build I've upgraded from used a Be Quite Dark Rock 2 which I belive to be unsupported by Be quite on the AM4 platfrom
I planned on picking up a mounting kit from them for my dark rock pro. But as far as I can see they don't sell them for the 2nd gen model. Only the 3rd and 4th gen Dark Rock Pro coolers are now supported on the lastest Ryzen Platform.
I was going to just hit buy on the new Dark rock pro, it's been a great cooler on many builds for me.
But then I thought the whole point of this build was to have some fun and build a cheap AMD build so spending £80 on a cooler is overkill for a 95 watt part.
So could anyone recommend me a good decent cooler - had a good dig myself and this is the best I've come up with, anyone recommend anything better for under £50?
https://www.overclockers.co.uk/be-quiet-pure-rock-cpu-cooler-120mm-hs-010-bq.html
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
![Mad :mad: :mad:](/styles/default/xenforo/vbSmilies/Normal/mad.gif)
