Air Cooler for X570 Aorus Xtreme
21 Oct 2004
Wales
Gigabyte X570 AORUS XTREME (AMD AM4) DDR4 X570 Chipset EATX Motherboard | OcUK (overclockers.co.uk)
I bought this board from the members market and now I need a cooler for it. I am currently using an NH-D15S on my current motherboard and I tried to use it on the Xtreme but I found that the cooler blocks the first PCI-E slot completely so I need a smaller cooler but am unsure of one that would be adequate for my needs. Right now I run my two fans on my D15s at about 600rpm on my 5900X and it is more than enough cooling while keeping my system very quiet ( I have hypersensitivity to sound ) and of course whatever I replace it with I would like to keep it at roughly the same noise level.
Any suggestions for a cooler that would not cover the PCI-E slot while being quiet would be ideal and as for AIO's I have tried them but the buzzing from the pumps is too distracting for me. Anyway hope you are all keeping safe!
Yeah I thought it would fit as well but I tried and it simply wont allow the first PCI-E slot to be used. And yeah the DRP4 looks a good candidate... i'll add that to my list
Thermalright's new Frost Commander 140 (in silver, black or white) is 62mm center CPU to side of fins toward PCIe sockets (NH-D15S is 67mm) is actually a little better than D15/D15S and usually much lower priced. Problem is finding them. :(
