Hi guys i'm looking for a bit of advice on cooling.
I'm about to embark on a new build and my core components will be a fractal design Define R5 case a core i7-4790 cpu and gigabyte z97xud3h BK motherboard with some decent DDR3 ram.
The case comes with one 140mm fan at the front and one at the rear, my intention was to buy a 2nd fan for the front to increase air coming in but my main question is regarding the cpu cooler.
On my current pc i have a corsair H60 AIO water cooler with the radiator attached to the rear and set to suck in cool air, i currently have a top fan which sucks out the warm air. With the Define R5 you can of course open sections of the top and do the same however i'm trying to build a 'quiet' pc and apparently the more of these panels you remove on the R5 to add fans the less chance you have of creating that quiet pc.
So with the Define R5 having 140mm fans i could get the corsair H90 which i believe would fit just fine however i'm wondering if i'm going overkill here and i'd be better with a decent air cooler.
My intention is not to overclock so would the air cooler on the i7-4790 be just as good as H90 at noise and cooling?
Long story but i got there in the end.
As always appreciate any advice.
