Air Cooling a cpu
16 May 2003
Aberdeen
Need some help guys cooling an 8200stock
U see I am using water for almost 7 years now and as a result Iam way back whento comes intoaircooling a cpu..especially an Intel
Ok to the point... the pc I am building is for my brother in law which means that stock is most likely the only volts itwill ever see, however it will stay powered up 24/7 (download freek)
So.. what do I get him..?
Shall I go for the traditional faced down heatsink-fan?
Are the vertical heatsink better? and again fan pushing or pullin gair?
From what I looked around in the market I was consiering these 3 options:
1.Scythe Cooler Samurai Z Rev.B (22Euros)
2.Scythe Cooler Mugen (37Euros)
3.Noctua NH-U12P (59Euros)
Hope I am not causing any probsmentioning the prices but i wanted add this to the equation as cost is an importantfactor in this build.
So what do you all think..?
Can u suggest something else for the job?
If it's only going to run stock then I don't see whats wrong with the stock cooler.
One of my machines, an E2180 @ 3.2GHZ runs 24/7 F@H with the stock cooler fitted.
It's in quite a small case but even so temps never exceed 60c.
If there's no overclocking involved and he doesn't already have the stock cooler then just get the cheapest available...arctic freezer 7 pro will work...also if he ever wants to overclock the AF7 is good for over 3ghz at least.
There was a batch of loud ones I think but that was some time ago. They're still decent and cheap. If overclocking then use the Noctua. I have it and it works wonders. I don't think my E6300 @ 3.15 has been over 55C since I installed it.
tobe honest I was quite fond of the Xigmatek HDT-S1283
it goes for 33Euros and it offers an allaround package...
..what do you think..?
I mean descent size, could upgrade the fan if you want and good price
only thing putting me down is the cpu contact surface :(
i think you're thinking like an overclocker :p if you're running the cpu at stock i really can't imagine you need to worry that much. the ac7pro is at a good pricepoint and will keep the cpu chilly easily at stock.
hey guys... here is Greece...
summer time it hits 43 *C
try cooling under these conditions
and u cant have airconditions running 24/7
I had my E6600 running at 28 degrees C passively cooled using my Thermaltake 120 Ultra Extreme so was silent :D Sure if you wanted you could probably do that though you'd want some good fans in your case. Otherwise get a 120Ultra extreme and throw a quiet Noctua on it. Looks great and can't heard it.
Just my 2 cents, might cost a little more than some other the other suggestions made, but it's not going to be noisy, hot or let you down any time soon.
