Air cooling advice
18 Feb 2009
hi guys,
just wondering whether i could tap into the forum database (you lot)!. I have a coolermaster cosmos s on order, and i'll be fitting it with an E8400, 4 gig ram, HD4870, and a new psu which i'm not sure which one to get yet!, i'd like to fit some extra fans to it, but as this is my first case and cooling upgrade, i'm unsure of which fans to fit, and would appreciate some advice on what to look for when buying some new fans, and any suggestions are welcome :D
Normally i'd recommend a cooler like this, but due to the massive side fan on the cosmos s - it won't fit (nor will most large air coolers).
With this in mind, i'd recommend this (Corsair H50). From everything I have read about it so far, its cooling performance gives the best aircoolers a run for their money. Plus it is very quiet and easy to install. You could always add a few good fans to it (like these) and bring the temps down even further.
Not to mention the noise... although i've heard mixed reviews about the noise of that thing. Some say it's very quiet, others say its a fairly laud pump
