Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
Hi all, I am considering going back to air cooling after over 15 years of watercooling. The reason I watercooled in the first place is because my computer room was a paif of cupboards knocked into one with no windows so I had to remove the heat from the room. I did this by putting my radiators in a box on the landing windowsill. I am now in the spare bedroom and still use outside air through the radiators by having them in a box on the windowsill. This does involve around 12m of 12mm copper pipe, 10/16mm Mayhems soft tubing, 12mm PETG hard tubing and a pair of D5 pumps. With overclocking giving only minimal gains these days I think my overclocking days are gone so apart from the silence and very low temps there isn't much point of watercooling anymore. With that in mind I am considering going back to air as it is much less hassle. My gpu already came with a excellent air cooler so I only have to worry about the gpu. The whole intention of my current build was to drop something like a 13700k in it a year or two down the line when they start popping up in the MM after people upgrade to the latest socket. What I would love to know is peoples experience of cooling high(ish) end cpu's (not just Intel so 12700k and up, AMD 5800 and up) on air, that's proper air cooling, not AIO's. So if you have the time could you possibly list the following please:-
1. Which CPU and stock or clocked?
2. Which cooler?
3. Peak load temps while gaming and if possible your rooms ambient temp?
I appreciate that not everyone will have the time to reply so a massive thank you to everyone that does.
2. Which cooler?
