I was thinking about getting the Corsair H50 cooler for my new build but I need some advice on airflow.
As you can see from the picture I have 3 X 180mm intake fans at the bottom of the case. The exhaust fan is supposed to be at the top of the case but this is the place where the radiator would go.
Would it be bad to have warm air from the case passing through the radiator and being expelled out the top?
What would you do?
Thanks for the help
What would you do?
Thanks for the help
