air flwo fan set up in bitfenix shinobi case(windowed)
14 Dec 2011
England - Doncaster
ok so i have 5 fans all togethers (strangely none came with the case :S even though most ppl get a fan with the case.. i should look into that.)
anyway i will explain where the possible fan positions can be.
I will post a pic of the positioning ive considered. and would like to know of a better option for better air flow.
red = intake / blue = exhaust
i forgot to show the other positions the fans could go. ohwell i could either put a fan on the bottom of the case to the right. or just below the intake fan on the right(right side of pic / front panel.)
Traditionally top/bottom/side = intake, rear/top = exhaust
Depending on you're GPU you may want to switch the side to exhaust. If its a reference blower then intake, if its aftermarket/non-reference you may want to consider exhaust.
The arctic cooling aftermarket HSF you may want to put the side fan to exhaust.
Reference blower = pushes air out of the rear of the card, so it needs to be fed with cool air (intake).
Aftermarket/non-reference = pulls air onto the heatsink resulting in the warm air remaining in the case commonly known as 'dumping hot air'. In this case exhaust for the side.
Reading this has just made me think, is my asus cutop gtx460's fan pulling or pushing air from itself, my side fan is an intake, but on a cold day my idle temps is about 23'C.
Really? surely you want top ones to be exhaust. Having a top fan as intake just goes against the way the heat will flow naturally.
Ah. I think you meant front/bottom/side ?
