Air grab??
6 Mar 2004
North Wales (Flintshire)
Any body use this on there Mac? I have just downloaded it and moved it over to applications, open apps folder, click air grab apps goes out of sight (as it should) but nothing happens with this air grab. Any idea's what i can do?
Other question is there anything else i can use on either MacBook or Iphone that will allow me to check what wireless networks are around and what channel there using?
Thanks.
Hold the option key and click your wireless icon in the menu bar, highlight the other signal you're querying and it tells you all about it.
