- 8 Nov 2019
Hello,
I have finished my loop yesterday and it is my first custom loop build. ( well at least the loop part.. haven't started cable management..gosh)
Also, used ekwb leak tester to test the loop for any leak issues.
My questions is I had air pumped in so the meter (bar unit) would stay on just past 0.5 bar (green zone) and there were no problem.
When I pushed little more to 0.6 ish, one of two parts of the loop keeps popping out making loud noise. Note that I don't really think this is air leaking at all. It is air tight and it's just pushing out of the fitting looks like.
I have a 90 angle fitting connected on the reservoir outlet to GPU as L shape and I think it just too movable and that is why it's causing it and I don't think it is got to do with broken O-ring or something else?
Could anyone give me some advice on how to fix this issue?
Or having no air leak on 0.5 bar would just do it after all?
I will attach pictures for easier understanding.
