Air.air or AIO for a 13700k if you move the PC around and are a bit rough with it?![]()
Air.
Or just make sure that you don’t end up with air in your AIO pump.
Gamers Nexus did a whole thing about how if you rotate the AIO and the residue air left in the loop ends up in the pump, the pump will die pretty soon.
Never had an issue with an air cooler and movement.
NH15 will be fine.Thank you.
I do want to go air was commited to it. However I'm now a bit concerned re: noise of the GPU. I'm getting an ASUS TUF or STRIX (I have to because I have 5 displays, 4 active at any one time).
They suffer from coil whine.
I'm not sure how a Noctua NH15 will fare in a Define 7/Noise dampening case.
Thank you. Even in a Define 7 case mate?NH15 will be fine.
I have no idea. I’m not an independent reviewer.Thank you. Even in a Define 7 case mate?
I've seen the temps are quite bad in it when it was intiially reviewed and no longer on reviewer's graphs.
