Air or water?
10 Jan 2005
Trowbridge
Hey all,
I am currently running a water cooled rig (below in sig) however i have just got myself a i5 2500K and will be ordering the 680 tomorrow.
What i cant decide is if i should continue with water (which i do like) or go for top end air cooling. I would like the rig to be as near silent as possible.
Now if i was to go the water route what would i need to change on my rig to allow me to to so? Obviously I have to wait for the 680 blocks to come out and replace water/tubing etc, but what about the CPU block? Can i keep that or would i have to replace that also?
If i was to go for air, I relly have no idea what heatsink to go for either.
What are peoples thoughts on this and what direction would you take?
Keep the water if you're happy with it, probably get a replacement CPU block for less than a decent air cooler i'd imagine?
Also from looking at your sig, you're ditching vista, right? ;)
I am happy, just a case of how much water will cost more than air, but looking at it all i need to buy is a GPU block (when available), CPU block, tubing and water. Pump and radiator are both good :)
And Vista went a long time ago, although i never had any problems with it :cool:
Vista is a good OS now. Wasn't at the beginning though!
Windows 7 is a lot better, I never really had any problems with Vista either, but see no reason for anyone to run it these days.
Can't see CPU block costing that much more than a decent air cooler - I'd personally keep the water.
I was in the same situation and ditched the water, and I do miss it :)
Cpu block = XSPC Raystorm, probably one of if not the best CPU block on the market, retails at £49.99 or you can go full copper for double the price.
It won't be long until the 680 FC blocks are out, EK were pretty quick off the mark with 7970 blocks and no doubt have had a 680 reference in possession for a few weeks to measure up for blocks.
I can afford to watercool so may as well. Only annoying thing is they have run out of 1/2" tubing which complicates it a bit :(
Now teh decision of wait or change barbs for smaller tubing, the joys :S
Personally when I upgraded to i7 I went back to a good air cooler. The i7 is a lot cooler than the Q6600 that I bought the water cooling for originally. The noise is about the same as I didn't have the graphics card water cooled. From what I have read the 680 is quiet compared to other cards (e.g. the 480 which is dam loud).
