Air purifier
23 Apr 2007
Cardiff-ish, Wales
Hi guys,
does anyone here use an air purifier to reduce the amount of dust build up in their computer room? I'm running two gaming rigs plus a home server and the dust builds up quite a bit. I thought that an air purifier might help reduce this.
Any thoughts?
Cheers,
Jed
Hi guys,
Any thoughts?
Cheers,
Jed
vacuum regular, keep windows closed(one of the biggest causes of dust) keep the room door shut if you can. purifiers not really going to do much to be honest. only other way is to create a positive pressure in the case that will limit it somewhat becuase your not sucking air though all the unfiltered gaps.
