Air then water!
10 Jul 2013
Space
Got a situation here bout my case choice! I pretty much know I will be installing a full water loop in next year so in the mean time I will be using an air and h100 for now what case would u recommend? I pretty much had these in mind:
Corsair 540
Corsair 600t
Phanteks enthoo
Nzxt switch Matt black
I really like the phanteks case but not sure how it would fair seen as there isn't any feedback on it. I also like the 600t but cannot find a nice window for the black edition. The others are back ups I'm put off the 540 due to the layout of the optical drive ( I will use)
If u have experience of these will appreciate feedback, and like I said I will put my whole system under water in the near future so water features is a plus :cool:
Ive got the 540, and its an awesome case. I too use the optical drive and I've had no issues with it. Ive only got it on air, thats fine for me right now with temps and noise. If you did pick this case I don't think you'd be disappointed.
The reason why I'm sceptical is coming over from consoles u could stand them up but the disc seemed to scratch an make abit of noise in the disc tray, unless u had a slot loading drive I couldn't see a resolution
