Air to water
10 Aug 2006
Warrington
Hey guys
Currently have the components in my sig and the noise is starting to annoy me. I have the case fans on medium or high, but the tuniq tower on "pwn" is creating the most noise i think.
Basically I have no idea about water cooling and was wondering what the options are.
Should I get a water cooling kit or buy each part seperate, and if so, which kit/parts are considered the best bang for buck.
Also, when cooling my pc via water cooling would I be able to run all case fans on low and still see low temps?
Also do any of you know of any good water cooling guides? so that I know how to install the stuff once I get it.
Cheers
Ben.
Generally the Swiftech kits get a great writeup (its what i still use) and there are some very good cooling dedicated UK based sites that can help but i cant mention as they sell PC hardware.
I have built a well OCed system on air that is not far off silent, Your gfx card isnt loud so maybe a Swiftech H20 120 Compact Kit @ £76.36 inc VAT will suite you.
