Air trapped in loop
28 Jan 2015
apart from the bleedin' obvious, is there a way to remove a bubble which is trapped in a cpu block (phanteks glacier). I have bled the loop, jiggled case numerous times- not easy when it is a Phantkes Enthoo Primo as bloody large and heavy and have left the pump running for most of a day and I cannot remove this bubble from the block.
Any ideas please as I want to give this build to my sister in law asap as its doing my head in
have you tried laying it flat .. just remember to keep the res at the highest point ..
when I drain both my loops takes me hrs to get the air out most of the time I need 4 pairs of hands ..but the wife still loves me :P
Can you adjust the speed of your pump? If so, ramp it up and down a few times, I find that soon shifts it and is a good test for leaks too.
That and time, it generally all vanishes in the first week unless its a massive empty area...
Can’t squeeze tubes as petg and will connnect pump up to Aquaero6 and play with the speed settings if I can remember how to get the pump recognised
