Hi all, I'm after some advice about the aircon and climate control in my car
It seemed to work albeit not always very cd so I made the mistake of taking it to said garage to get it regassed. After waiting a hour the guy came and took the pipework off. The valve now leaks gas
which it didn't before as the machine recovered almost ad much gas as was pit in.
Initially on startup it didn't work and his gem of advice was to run a now cold dci at 4000 rpm as apparently it needed this to work. I refused this, took it around the block instead, came back and it didn't work.
I'm sure on my sisters car the engine cooling fan comes on with the aircon, mine doesn't - related? Do I now have to take it somewhere to get this valve replaced? Any other suggestions?
Thanks
Thanks
